Results 1 to 4 of 4
Thread: rd28 starting issue
    Oct 2022
    rd28 starting issue
    Hi guys,
    Having problems with starting my RD28 patrol, will start with "start ya bastard and will start again with every try within the minute, if i let it sit for 20mins wont start again without the spray", injector pump replaced, timing is 100% all good, fuel filter brand new, primer stays hard glows plugs new, all belts done, has fuel in tank,no idea where to go from here
    leaning towards something to do with the fueling.
    Qns:
    Could it be the timing of pump, if advanced would it help starting?
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Check/set valves.
    New glow plug wont help if no power getting to them. (check controller)
    Sucking air to injector pump? Solenoid there staying on? (check relay)
    1989 LWB 5-Seat, TD42
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Or you might have just given her an ether habit :/
  5. The Following User Says Thank You to mihit For This Useful Post:
    MB (5th October 2022)
    475 Post(s)
    GOLD @mihit Mate
