Page 1042 of 1053 FirstFirst ... 425429429921032104010411042104310441052 ... LastLast
Results 10,411 to 10,420 of 10524
  1. #10411
    465 Post(s)
    I am contemplating retro fitting up the new Donaldson LC200 air box into my GU as the Fatz Fab pod box is shit.
    Just means I gotta move the aux battery, which means buying a lithium, which means buying a new DC/DC charger, which means big dollars for the lot!
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    PeeBee (14th January 2024), Stropp (15th January 2024)
    Apr 2021
    Brazil
    Is the new box just that shallow or is it just a cover or something?
  5. #10413
    465 Post(s)
    That’s the shape of them.
    Not sure if it will fit though.
  6. #10414
    475 Post(s)
    Honest opinion @mudski Brother
    I have never looked back after honestly taking @nissannewbys advice on these compact rippers
    https://www.roadrunneroffroad.com.au...-Turbo-LS1-LS3
    Scored mine back in the day for half the now price linked above but with a cheap V8 high performing ‘paper’ flat easy stored replacement filter A1358 from any cheap store Australia wide.
    Suited my then 55rwkw TD42 and now pimped to 155rwkw TD42Ti it’s amazing and worth every penny
  7. #10415
    475 Post(s)
    A bit more clarity (pictures) in honour of NNB-NP.com.au Guru super helpful guidance here back in the day
    It still is a bit messy atop but can easily filter pimped up TD42’s to well above my original numbers
    Above…. I did personally modify their emergency drain flap/hole with a local plumbing store ‘Philmac’ check valve although it has never been needed utilising under/after windscreen deep Tasmanian pot holes still to this date
    Matt… @nissannewby Legend kindly did all the flow rate air numbers needed well before even the Airboxes creation numbers too
    Crikey, these A1358’s are cheap, available most outback places and so so so easy to pack under your seats or in your cavities
    mudski (17th January 2024)
  9. #10416
    May 2016
    lower west victoria
    30 Post(s)
    looked at the leaking drivers side hub .... again.
  10. The Following User Says Thank You to 10G For This Useful Post:
    MB (16th January 2024)
  11. #10417
    Apr 2021
    Brazil
    Not sure that is a selling point for him, LOL.
  12. The Following User Says Thank You to BrazilianY60 For This Useful Post:
  13. #10418
    475 Post(s)
    Quiet time in Australia BZ Mate , well after Midnight Ya Mad Bastard
    Send us all Pretty Please some Brazilian Shenanigans
    BrazilianY60 (17th January 2024)
  15. #10419
    475 Post(s)
    You’re Lazy, had to McGoogle your country again YOU Lucky Bastard
    https://youtu.be/7lc9bcN7ecQ?si=3WbW6LrfdwQC25Q_
  16. The Following User Says Thank You to MB For This Useful Post:
  17. #10420
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    flushed my radiator until it was clean
    2008 CRD Auto Wagon
  18. The Following User Says Thank You to pollenface For This Useful Post:
    MB (22nd January 2024)
