Results 1 to 5 of 5
Thread: Wheel Arch and Barn Door Paint Repair
    Aug 2023
    Geelong, VIC
    Question Wheel Arch and Barn Door Paint Repair
    Hi All - first time poster here
    I have some paint chipping / peeling / bubbling on the wheel arches and plastic outer panel on the LH barn door on my '08 GU (images attached).
    I am thinking of using the ColorSpec touch up from SuperCheap and following the sand, prime, base, clear coat process to tidy these up. Have never done it before though and wondering if anyone has used these products for a similar job or would recommend something else?
    Any advice much appreciated!
    Cheers,
    Roberto
    IMG_0256.jpgIMG_0255.jpg[ATTACH=CONFIG]87166
    465 Post(s)
    Could be done but won't come up anywhere near a pro job. If your happy with that, then go full steam ahead. Light thin coats, then spray some clear on it.
    paxrobertus (10th August 2023)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    2-pak paints will always come up better, but does require the full setup. And they'll kill you.
    If you're going rattle-can job, then prep, prep, prep.
    If you can leave the panel in the sun or under a heat lamp until it's warm to touch, that's good.
    Stand the can in boiling water until the can is warm as well. Shake it like it owes you money.
    Mist coat first. This is literally as little as you can detect on the surface.
    Follow the instructions for recoat-times, your next coats can be full thickness. But many light coats beats few heavy ones.
    1989 LWB 5-Seat, TD42
  6. The Following User Says Thank You to mihit For This Useful Post:
    BrazilianY60 (11th August 2023)
  7. #4
    Apr 2021
    Brazil
    Quote Originally Posted by mihit View Post
    LOL. New one to my dictionary!
  8. #5
    465 Post(s)
    Shake it like a polaroid picture.
    Fixed it for ya!
    MudRunnerTD (11th August 2023)
