Results 1 to 3 of 3
Thread: Hopping in 1st at low speeds
    May 2016
    lower west victoria
    30 Post(s)
    It went away when I first put in my Dawse & Needle valves. But when rolling along above idle in 1st, while holding the accelerator peddle constant, the Patrol hops, you get that action that happens when you let the clutch out quick without enough revs, it goes away once you increase speed.
    I thought that was caused by the computer giving dickie info out to the whatever it is that makes the car hop and that is remedied when you put in a Dawse valve. Do I need to adjust something?
    That generous guy @bigguwesty who helped me with my Dawse install told me I may have to stretch the Dawse spring after 6 months. Could it be just that?
    Thanks for any help.
    what condition is your IC, check all vacuum hoses for cracks it may be leaking.
    If IC is oily its leaking, they all do. You may need to install a needle valve
    Is your EGR blocked. Year and motor would help a bit
    465 Post(s)
    Stretching the dawes spring is not needed. That only applies to dawes valves about 4 years and older. There was a design change back then to correct this.
    Sent from my GT-N7105 using Tapatalk
