Results 1 to 8 of 8
Thread: Remove aerial - GU1
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Remove aerial - GU1
    G'day, how does my aerial unscrew? I watched a vid and the aerial had a hex but to undo. Mine has these holes, not sure how hard to tap
    .......from under the great down under.
    Hello from Under Down Under!
    109 Post(s)
    Yeah mate get a couple of prongs in those holes and unscrew. Circlip pliers if you have them will do the trick.
  3. The Following User Says Thank You to Plasnart For This Useful Post:
    taslucas (11th December 2023)
    468 Post(s)
    Why do you want to remove it? You need to remove the inner guard to drop the aerial and motor out, and I'm pretty sure theres two bolts, or nuts, that you access from the LHS of the foot well. I replaced the antenna cord in mine a long time ago and had to do this. Then I was sick of it going up and down everytime I turned the ignition on so I just left it down and disconnected it and put a whip antenna on the bull bar.
    587 Post(s)
    Can you please show me a link to mr whippy?
    I’m sick of having no radio, the aerial is a nightmare to replace and mines electric too.
    Apr 2021
    Brazil
    It uses a tool like this (we call it "vampire" over here) but it is pretty easy to improvise.
  7. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    AB (12th December 2023)
    468 Post(s)
    Something like this one. Pretty sure its what I have....
    https://www.gme.net.au/au/antennas/aem2/
  10. #7
    587 Post(s)
    My aerial is stuffed and I tried to remove it using circlips but it just wouldn't budge.
    It also looks impossible to get to it under the panel so is that true you have to actually take off the panel?
    That would be a nightmare with my set up with the snorkel, etc too.
  11. #8
    468 Post(s)
    Well in the GU im 99% there is two bolts via the LHS kick panel, then the entire motor and aerial drop out from behind the inner guard. I just left the aerial there and in the down position and just disconnected it.
