Results 1 to 10 of 14
Thread: Electronic Corrosion inhibitors
    196 Post(s)
    After seeing the corrosion on @Nhoward vehicle and knowing that I am setting my vehicle up as a keeper, I am wondering about peoples experiences with the installation of electronic rust preventers or corrosion control devices. Some use a sacrificial anode, others induce a charge into the body - who has used one, what were your results, impressions and recommendations? I don't expect to see a lot of salt driving, however the truck is being set up for some extended travels, so beaches are a certainty.
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    It’s been covered a few times over the years, here’s a link to one thread but there are several others:
    http://www.nissanpatrol.com.au/forum...ust+protection
    Jack
  4. The Following 2 Users Say Thank You to jack For This Useful Post:
    Cuppa (26th February 2020), PeeBee (25th February 2020)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    From my own personal experience, after cutting fist size rust holes from my sills, mine went straight in the bin, a peter brock crystal polarizer would have been a better investment
  6. The Following User Says Thank You to 04OFF For This Useful Post:
    Rossco (27th February 2020)
  7. #4
    Quote Originally Posted by 04OFF View Post
    Certainly would be now since Holden got axed.
  8. The Following 2 Users Say Thank You to mudski For This Useful Post:
    PeeBee (27th February 2020), Rossco (27th February 2020)
  9. #5
    196 Post(s)
    Can you recall what the brand and system employed to 'protect' the vehicle?
  10. #6
    80 Post(s)
    The systems only work when there is moisture present, anyway.
  11. The Following User Says Thank You to mudnut For This Useful Post:
  12. #7
    Brisbane,QLD
    12 Post(s)
    Sorry man, waaaaayy too much other life episodes and many many beers ago for me to remember, but pretty much insert any brand name, and ill bet my lefty it will be just as "good".
  13. #8
    Ballarat, Vic
    175 Post(s)
  14. #9
    196 Post(s)
    Thanks Cuppa, the "Colin" article is of value as it shows a time based result and some real conclusions. I was thinking a sacrificial anode style device is what I am looking towards, however further investigation has steered me away totally from this form of corrosion reduction - simply does not stack up from the 'science perspective'..
  15. #10
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Sacrificial anode protection will only work if the items (both the anode and the item being protected) are immersed in an electrolyte of some sort, so useless in this situation - unless you are thinking of drowning the beast in the ocean of course.
  16. The Following User Says Thank You to Brissieboy For This Useful Post:
    PeeBee (28th February 2020)
