8th January 2020, 10:08 PM
#4751
After seeing @PeeBee's electrical overload melting his CTEK and this video of a VW catching Fire from an electrical fault (https://youtu.be/6VTZmp3oPz0) I picked up a 1kg Fire extinguisher on sale at Bunnings today.
$16.89 down from $19.90.
I also grabbed some scrap aluminium from the metal recyclers to make a bracket to mount it in front of the passenger seat.
The Following 2 Users Say Thank You to Cremulator For This Useful Post:
Avo (9th January 2020), MB (9th January 2020)
8th January 2020 10:08 PM
8th January 2020, 10:33 PM
#4752
Cremulator
After seeing @
![](http://www.nissanpatrol.com.au/forums/images/imported/2020/01/93.jpg)
Good choice but a simpler solution, in my case anyway was to simply concentrate on what I was doing and put my brain into gear.
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
Cremulator (8th January 2020), MB (9th January 2020)
8th January 2020, 11:04 PM
#4753
Moderator
Cremulator
After seeing @
I have 2 in the GU. I have used one on a fully involved engine fire of a Commodore in the middle of the road. Saved his car for sure.
In have mine mounted to the base of the B Pillar behind he driver's seat. Is perfect there. They really should be mounted standing if possible.
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
8th January 2020, 11:14 PM
#4754
That's good to know @MudRunnerTD I'll look into that.
9th January 2020, 01:11 AM
#4755
VDO boost guage, steering dampener, 2nd hand tow hook (mine is missing).
9th January 2020, 10:43 AM
#4756
Breadmaker Shaker
MudRunnerTD
And turn upside down and tap with a rubber mallet every 6 months or so to stop the powder settling.
![](image.php?s=50b7f264a9102c686f3c385ecfac9283&u=115&type=sigpic&dateline=1651651487)
9th January 2020, 10:44 AM
#4757
Well, another wire solder kit arrived in the post today, must have ordered it, cant remember. This one works as intended. It has a tricky plasitic sleeve over the solder that is used to house some small red locator and guide rings to assist the wire pigtails getting aligned inside the solder donut. During the solder melt stage, the plastic shield degrades/disappears. a supplementary shrink sleeve is supplied and then slid over the heat affected zone to complete the joint. It is a good system I think, does it save time over the more manual wire twist solder then shrink sleeve - maybe not, however it hoes have all the bits in one place and pre-cut for use. wire solder kit.JPGsolder joint 2.JPGsolder joint 2.JPGsolder joint 1.JPGfinished joint.JPG
Looking at the soldered joint it looks pretty average, however I think this is the plastic melted on the outside - the solder definitely runs thru and over the entire wire joint and is mechanically sound.
9th January 2020, 11:07 AM
#4758
Cremulator
After seeing @
I got two in the front of the GU, one in front of each seat on the floor.
When they go end of life I'll be replacing them with the newer style of exitinguisher. Can't remember what they're called, but they're smaller & last longer and I don't think they have an end of life date.
The Following 3 Users Say Thank You to 10G For This Useful Post:
Cremulator (9th January 2020), MB (9th January 2020), PeeBee (9th January 2020)
9th January 2020, 05:06 PM
#4759
10G
One of these?
https://fire-one.com.au/products/fir...in-your-pocket
The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
10G (10th January 2020), MB (9th January 2020)
9th January 2020, 05:57 PM
#4760
Hi all. Ok, I havent bought anything today, but I am looking at 3 inch exhausts for my budget build zd30 2002. She owes me less than 6k and I am looking at catless but with muffler stainless ebay specials PPD and Ultrex. ( around 600)Any ithoughts??
Cheers, Mick
