21st January 2018, 10:50 AM
Lift Height on my Patrol
Hi all. Proud new owner of a 2012 GU CRD
I'm trying to work out how much it has been lifted if any. Starting to make improvements and additions to her and starting off with new wheels and tyres.
My measurements running 17" stock rims from bottom of rim to wheel guard is 850mm rear and 810mm front. From the centre of the rim it's 580mm front and 620mm rear.
I haven't been able to find factory heights for the vehicle yet...
Sent from my Pixel XL using Tapatalk
21st January 2018 10:50 AM
21st January 2018, 11:01 AM
Looks like a 2" lift from the photos , there is a stock overall height on a thread here somewhere try the search bar top right side .
The Following User Says Thank You to GQtdauto For This Useful Post:
denk82 (21st January 2018)
21st January 2018, 11:03 AM
GQtdauto
Cheers thanks for the heads up
21st January 2018, 11:47 AM
Check here for all your Y61 specs via Road Vehicle Descriptor Details
The Following 2 Users Say Thank You to TimE For This Useful Post:
denk82 (21st January 2018), the evil twin (21st January 2018)
21st January 2018, 09:17 PM
TimE
Check
Thanks mate
23rd January 2018, 03:01 PM
heard somewhere the police measure mudflaps at 300mm to the ground any more theyll bust you.
Happy to be wrong
24th January 2018, 08:48 PM
Definitely looks like a 2" lift.
I measured a standard GU Ute on flat ground at a dealer to check against my wagon, and I measured bottom of the rim to wheel arch ( normal way ), and also measured ground to wheel arch. Can't find the bottom of the wheel to wheel arch measurements, but found the ground to wheel arch at 920mm.
I did it this way also, as that is the way I thought the Police may check as they wouldn't have the other measurements, and would be looking for the overall 75mm change in suspension height limit
The Following User Says Thank You to happygu For This Useful Post:
denk82 (8th February 2018)
24th January 2018, 08:54 PM
Dribble Master
I always measure from centre of the hub to the wheel arch, takes into account differences in wheel diameter.
But another vote for looking like a 2in lift
24th January 2018, 11:43 PM
I am he, fear me
Clunk
X2 and X2
Suspension lift and/or/either Body Lift is measured hub centre to wheel arch
