Results 1 to 10 of 14
Thread: Winch free spool is not so free. Winch clutch adjustable ?
    175 Post(s)
    I pulled the rope out to dry it out a little bit, which I do every couple of months, every time I service the car.
    This morning when pulling it out, in free spool, I just about had to brace my leg against the bull bar to yank the rope out. It's very hard going. I remember last time it was similar but not as bad...
    Also in free spool, running the motor in and out, also drags the rope in and out... But I can grab the rope and hold it, which stop the drum from spinning while motor is still going. So clutch is not disengaging all the way...=
    Are clutches in these adjustable ?? Does anybody know.
    When clutch engaged, the winch pulls in and out no dramas.
    The winch has actually NEVER been used or load put on it. Since owning it (about 2 years) the ropes just been in and out a few times to dry it out etc....
    Before I pull it out and rip it apart. Thought I'd ask.
    My winch is the Runva XP11 Premium.
    It has a different clutch selector to other Runva winches and other brands winches I've had experience with. It's kind of spring loaded in and out instead of the physical engaging lever.
    This from their website:
    "This model features the newly designed gearbox with integrated ratchet braking system. "
    I wonder if that has something to do with it.
    http://www.runvawinch.com.au/11xp-12...h-dyneema-rope
    https://www.4x4australia.com.au/gear...h-product-test
    It is winter so the grease in the box will be thicker.
    But if your worried about it id say remove and pull it down and maybe new grease..
    Ive pulled my 11xp down twice now in 4 ish years.
    Lubricated seals and gears.
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Hodge (8th August 2017)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    The lever for free spool is in an awkward spot on mine and if not properly engaged it will do what your describing , having a wire rope birds nest on the drum doesn't help either .
  6. The Following User Says Thank You to GQtdauto For This Useful Post:
  7. #4
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    I'll second the motion that it needs a service, the Runva's are pretty easy to disassemble. When you service it, don't go overboard with the grease, too much can make the free spool harder, make sure to use a good quality marine grease.
    Edit: I just read the bit where you mention the premium edition has a different style clutch, I'm not sure how it works, but Runva should have a manual for it with an exploded view diagram for disassembly?
  8. The Following 2 Users Say Thank You to stevemc181 For This Useful Post:
    Hodge (8th August 2017), MB (8th August 2017)
  9. #5
    175 Post(s)
    Thanks fellas. I think westy is on the money. I'll have to strip it down and have a look / re-grease. I still have warranty on it, but when I mentioned the problem to them the first question asked was did I unwind and wind the rope back in every 4-6 weeks since purchase? Lol
    @stevemc181
    I think the internal part of the clutch is the same... The switching is different as it's kind of spring loaded. Mine is just a flick of the switch, almost like a large electrical switch. But the other Runvas have the selector where you physically feel that you're engaging or disengaging something.
  10. The Following User Says Thank You to Hodge For This Useful Post:
    stevemc181 (8th August 2017)
  11. #6
    475 Post(s)
    Apologies butting in truly uninformed gents but I thought I read on here somewhere a while back that grease packing elecy winches was not so good? Do remember reading a thread somewhere discussing 'Warn' oil only not grease but 'Runva's' can't be sure if that was discussed or not :-( ?
  12. #7
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Most winches I know of use grease in the clutch end, I've never had an issue repacking the ones I have serviced. There is a bit of a write up here on a Runva 11XP I did a few years back. https://www2.pajeroclub.com.au/forum...ad.php?t=41664
    Your winch will love you for it, and regular maintenance means it will work when you need it to. I've yet to pull down the Warn XD9000 fitted to the Patrol, but I'll be sure to include it in routine maintenance.
    If you pack too much grease in, it will be harder to free spool, so you need to be sensible and not fill the thing with grease.
  13. The Following 3 Users Say Thank You to stevemc181 For This Useful Post:
    Hodge (9th August 2017), MB (8th August 2017), shantillylais (10th August 2017)
  14. #8
    475 Post(s)
    Cheers Steve :-) !
  15. #9
    175 Post(s)
    Thanks for that Steve! Will keep that in mind.
    Jul 2014
    6 Post(s)
    I have a Runva 11xp, and had the same issue a few years back. Good cleanup of the old grease and some fresh stuff fixed it up.
    Don't make the mistake of putting too much grease back in. I did this and had to strip it back down again, as it was just wayyyyyyyy to hard to move the freespool lever and freespool.
