I adjusted the idle on it, in the middle of rainy Marysville of all places lol. While waiting for DEPI to clear the road.
Thanks @nissannewby
Thanks @nissannewby
MB (10th April 2017)
Changed my drive belts, greased all the grease points, did an underbody / loose bolt check, replaced my fan clutch (only 2 years old :-( grrr), rotated my wheels, and had the joy of finding that not only was my fan clutch stuffed, but my steering damper has decided it doesn't want it's oil inside it anymore and let it leak out.... So now that's tomorrow's job after work
93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
Well... I looked under the bonnet again to see if I could find a good location to mount the newly purchased Redarc BCDC charger, but no luck. So I finally replaced a broken cig lighter with a Narva dual USB socket. I pulled the cig lighter out about 5 years ago, and today thought I'd fix it. I'm pretty chuffed! Now back to looking under the bonnet!
Took my intercooler off today and flushed it out to remove any oil that may be in there. Now I have convinced myself that it goes harder ha ha
Replaced my steering damper, new shiny one in place, so that's sorted 😀 Went for a test drive, and a bit of belt noise, not a squeal, more of a whine that has a pitch increase with revs. Charge rate dropped a bit, so I got home and checked the new belts, which seemed to have stretched a little. Tightened up the belts, charge rate now seems ok. Didn't whine before I replaced the belts, is there a chance a new belt needs to wear in a little and will quieten down? I hope so, the aircon belt sucked to get on, and it's in front if the alternator belt..... (Wetting down didn't help). Any ideas?
juzzs8 (13th April 2017)
I installed a Cel-Fi Telstra Mobile Booster so that I have better coverage when I'm out in my truck. It was expensive - but is legally certified so I don't attract the $25K fine for using an illegal signal booster!
Also relocated my bull-bar 4G Telstra Aerial to the back of the roof rack to avoid interference with the the internal boosted mobile signal.
Seems to work well ... but not sure I'll know until 50km out of Birdsville.
I also attached some 100mm PVC pipe to the back of my rooftop tool box so I can stick my tent poles in there.
2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
Got it towed from the mechanics back home
Mechanic managed 2 move the snapped spark plug a bit but couldn't get it any further, can't justify ( well I can but missus can't ) spending 1500 - 2k in removing the head and getting it machined, I'm not a happy camper and public transport 2 and from work sucks the big one
MB (11th April 2017), NissanGQ4.2 (11th April 2017)
Soak the damn thing with penetrene for a coupla weeks and have another go. Forwards - backwards. Or run it on five cylinders till it warms up and try again. I have had some success drilling out a fastener and peeling the thread out with a pointed pick. I suppose stopping any metal entering the bore is a problem, with that idea. I had to run a tap through the thread on number 4 cylinder when I first got my Old Trol. I used a vaccum cleaner with a small diameter rubber hose to suck out the swarf from the bore.
