Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Most flex from a 2 inch lift.
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    I've fitted an OME 2" lift with front sway-bar disconnects:
    Sway bar connected
    Sway bar disconnected
    Not a great deal of difference, I leave them connected most of the time unless I'm on a really nasty track.
    I use my car for a fair bit of touring so much prefer to have the sway bar connected, you can drive without it but its not ideal.
  2. #12
    22 Post(s)
    Quote Originally Posted by BearGUST View Post
    Sway bar connected
    by the look of the 2 pic. I'd say that the limiting factor is the shock length, that is why you see minimal difference
    96 GQ coil/Cab
    08 G6eT
  3. #13
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Agreed - can see what appears slightly more compression on the front, but no real difference in the travel of the rear ...
  4. #14
    22 Post(s)
    Quote Originally Posted by Bigrig View Post
    I see that too
    96 GQ coil/Cab
    08 G6eT
  5. #15
    Expert Mazodude's Avatar
    Aug 2011
    Forest Lake, QLD
    Can some one tell/show me what a manual sway bar disconnect is?
    I have hear about them but I just do not understand it.
    "Gunter" - 1993 Nissan Patrol GQ DX II, 6cyl 4.2L Diesel. 2" Lift EFS suspension. 33" Mickey Thompson MTZ (285/75 R16). Warn Winch
  6. #16
    22 Post(s)
    Quote Originally Posted by Mazodude View Post
    there is a lever next to the the driver seat. if you dont have one you need to buy disconnects from superior engineering. you need to get under the car to disconnect them. as good as they are I found them abit useless when disconnected as the became the lowest point of the vehicle. I like driving rock and ruts. more technical stuff and they were just asking to get ripped off
    96 GQ coil/Cab
    08 G6eT
  7. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Mazodude (9th February 2012)
  8. #17
    Aug 2011
    Forest Lake, QLD
    ahh. Seeing as I love rocks and ruts, I wont bother then.
    Thanks Ben-e-boy
  9. #18
    Patrol Guru paulyg's Avatar
    Ballarat
    Thanks guys, all good ideas, i want to keep the truck legal i cant be bothered with the the cops hassling me.
  10. #19
    Feb 2012
    To get maximum articulation, you need:
    1. Replace the front radius arms as they bind up. Something like the superiour engineering superflex radius arms
    2. Replace the rear lower control arms with longer links and a new welded chassis link, again superiour engineering have a kit
    3. Remove anti sway bars or use quick disconnects
